When I mistakenly double-tap the switches, the lighting system goes into a loop. this only happens with local scenes (ihost), it doesn’t happen in the cloud.
I have redone the scenes, I have made them simpler, that is, one order per switch. When there are three switches that need to actuate and one of them is double-clicked by mistake, it goes into a loop. This same test with 2 switches also gives repeat command problems when double clicked. this does not happen in the cloud.
Has anyone else encountered this problem? the switches are from the m5 series.
I have already sent the log
