Support Zigbee Sensors with soil_moisture cluster for eWeLink CUBE
Hi @yitie ,
I don’t know if this topic is still active, but I would like to inform you that I tested Tuya Soil temperature and humidity sensor (_TZE200_myd45weu) and it doesn’t work as expected: it shows only the temperature and not the umidity (device category = temperatureSensor). Here a debug of the sensor:
   "serial_number":"0xa4c13869d3ac0991",
   "name":"Plant Temperature Sensor",
   "manufacturer":"_TZE200_myd45weu",
   "model":"TS0601",
   "firmware_version":"1",
   "display_category":"temperatureSensor",
   "capabilities":[
         "capability":"temperature",
         "permission":"read"
         "capability":"battery",
         "permission":"read"
   "protocol":"zigbee",
   "app_name":null,
   "state":{
      "temperature":{
         "temperature":18,
         "updated_at":1714856777264
      "battery":{
         "battery":80,
         "updated_at":1714856777512
   "tags":null,
   "online":true
Do you think it will be fixed or I have to buy another device?
Hey
Thx for the info. There will be a big upgrade coming, please try again and see if it works till then.
Hey @misternails3,
A bit of offtopic:
How do you get this kind of debug JSON for a given sensor?
Hi, you need this very basic workflow:
@ward: I upgrade iHost to 2.0.0 version but as you can see above, the sensor is still a temperature one, so it seems there is no way to colelct also humidity data,
Thanks.
Hey,
Is this the model you’ve got?
Hi, I have this one:
I see what could be the issue:
Tuya reports humidity as soil_moisture, let me talk with our dev and see if we can have a workaround for it.
Hi @ward , do you have any news? My soil sensor still display only temperature, not humidity…
thx
hey
It uses a customzed entity: soil_moisture which is not supported by iHost at the moment. We will consider expending supported entities after a major update in core features.
Do you mind my turning your needs into a feature request so other users can vote?
@misternails3
Created. And I’m voting for it too as I have a similar model that Tuya gateway does not support to expose it to Matter. :rofl:
Thank you!
