Soil Moisture and Temperature Zigbee Sensor for Sonoff ZBBridge (Pro)?
Hello!
Does anyone know a soil moisture and temperature sensor that works good with Sonoff zigbee gateway (ZBBridge, ZBBridge Pro)?
Maybe something from Aliexpress. They sell such sensors for Tuya, but maybe someone uses them for Ewelink?
Thank you.
Regards, Oleg
For temperature, the SNZB-02LD will be suitable, but humidity would have to be measured separately.
For humidity, such a monster…
TH Elite + MS01
Or buy a good Tuya and connect Tuya-eWeLink via https://sequematic.com
Thanks for the reply. I need a simpler solution, like this sensor https://aliexpress.ru/item/1005008978391803.html?spm=a2g2w.cart.0.0.46cf4aa69RBckw&sku_id=12000047440771042&channel=choice
But I do not know if it will work with Ewelink.
I decided to buy such a sensor. If it doesn’t work with Ewelink, you’ll have to buy Tuya zigbee gateway.
I bought this sensor. It does not work with ewelink (only shows the temperature).
I just found this on AliExpress:
CZK194.19 | Tuya Zigbee Temperature Humidity Moisture Detector Smart Soil Tester Moisture Sensor Real Time Monitor Support Home Assistant Z2
https://a.aliexpress.com/_EJ0vvLu
hi this one works for me. it shows temperature and humidity
Tested on ZB Bridge Pro and compatible eWeLink gateway.
I need soil moisture value. Maybe humidity is air humidity here. But your sensor is better anyway, it shows 2 parameters, and mine only shows one.
I think it really is about the soil moisture. Before I put it in the soil, it showed 0, then when I watered it, it rose to 45 and after the rain it slowly drops from 95%.
I’m using the same sensor, but it shown values that does not correspond to reality. I water the flower and the sensor shows 20%.
Hi Spoucetaml, your link to ali-express shows 2 soil sensors. One is “Zigbee 3.0” and the other is “Tuya zigbee”. Could you please clarify which one you have, which works with ewelink?
Thank you very much
A.
hello. that ZigBee 3.0
