Can a SONOFF SNZB-02 Temp Sensor control SONOFF S31 Smart Plug through a Zigbee Bridge Pro Hub?
I’m trying to control a smart plug when the humidity drops too low. I assume these three would do that, but I don’t see how the humidity sensors control the smart plug or the smart plug sees the humidity sensor. Everything’s installed. Using eWeLink. Just don’t see how they control.
SONOFF Zigbee Bridge Pro Hub, ZigBee 3.0 Smart Gateway, APP Control and Multi-Device Management, Compatible with SONOFF Zigbee Devices
SONOFF S31 WiFi Smart Plug with Energy Monitoring, 15A Smart Outlet Socket ETL Certified, Work with Alexa & Google Home Assistant, IFTTT Supporting, 2.4 Ghz WiFi Only (4-Pack)
SONOFF SNZB-02 ZigBee Temperature and Humidity Sensor for Checking The Room Climate 2-Pack, ZigBee Bridge-P Required, Mini Indoor Thermometer Hygrometer with Alert, Compatible with Alexa
