I am reporting a regression issue with the “External Sensor” feature after updating the SONOFF SNZB-02DR2 firmware:
Issue Summary: My SONOFF SNZB-02DR2 was successfully updated to firmware version 1.0.5. Immediately following the update, the external temperature readings that were previously displayed on the SNZB-02DR2 screen vanished.
Troubleshooting Performed: I performed a full factory reset on the SNZB-02DR2 and re-paired it with SONOFF iHost. The pairing completed successfully.
Binding Process Failure:
When I open the SNZB-02DR2 settings in iHost and select an external temperature sensor, iHost prompts me to press the button on the back of the SNZB-02DR2 once to confirm the binding.
I press the button once on the SNZB-02DR2. The min/max temperature and humidity readings on the device display briefly disappear and then reappear (without showing the external sensor readings).
Simultaneously, iHost displays an error notification: “Failed to communicate with the device, please try again.” (or “Failed to connect with device”).
The Zigbee signal strength is excellent, and standard telemetry syncs normally. The failure occurs exclusively during the button-press confirmation step when binding an external sensor. This feature worked perfectly on the previous firmware version.
Please forward this issue to the SNZB-02DR2 firmware development team so they can investigate and release a fix.
