Hello, I use IFTTT to control my AC unit depending on power usage and have therefore hooked a Sonoff POW to the AC units.
It used to work like a charm!!
For the past 5 months, in the dropdown of eWelink in IFTTT the option “if power goes above”…“under” is no longer available. On my end I haven’t changed anything! I just want to understand why before I eventually switch to Home Assistant. Thank you!
Get, sth tricky happened in the integration with IFTTT, working on locating the root reason and find a way to fix, maybe IFTTT have modify the APIs again.![]()
