Hello. I need some help with a problem with an ifttt trigger. I found and error of comunication. I have multiple DIY powr2 with the last firmware, when select the triger “electric current goes above or below” from ifttt app on ewelink smart home, dont show my device
For the POWR2, at present users can choose to trigger ON/OFF, but you chose the electricity current goes above or below, that’s why IFTTT won’t display POWR2.
Hello Stephen, thanks for the clarification.
I’m putting together a control system for servers. Is there a model that allows using current and power values to create a scene? or that the ifttt triggers can be used?
did you already have a solution for this with the pow2
