Sonoff on HA via matter
Hi All,
I currently have my minir4m devices paired in eWeLink and into Home assistant through the sonoff lan integration running on iHost. ITV works after a power down but eventually stops showing correct state which makes the HA unusable. It still works in the eWeLink app and on the Apple home app. I have tried to get them paired through matter but can’t seem to do it on HA. I have an Apple tv which is recognised as a hub but I guess I need a how to get the devices on HA via matter rather than sonoff lan.
I don’t know if this can help you!
I connected my Sonoff devices to HA via the Sonoff Bridge Ultra as a Matter Hub.
Of the devices I own, the SNZB-05 (water sensor) was the only one that did not show up on HA Matter because it is not yet supported.
As far as I noticed, the entities about the battery charge are missing, but to begin with, nothing terrible because as far as I understand, everything is still in development and testing.
What is important is that you start the Mater Server on HA and add Matter devices via the Companion app! I think that MiniR4M devices should be added in the same way.
Please note: if I did not want my hub to be paired with the Matter server, I had to restart HA, it was not enough to restart the Matter server.
What matter server did you use? I can’t seem to get one to work on the iHost.
That’s the built-in one.
Use this entry from your phone (must be the HA companion app)
