Since at least 2024, many users of HomeAssistant noticed that Sonoff Zigbee presence sensor SNZB-06P sticks with occupied state in Home Assistant.
I was surprised facing it today that after more than 2 years the issue has not been fixed yet.
The issue came with firmware 1.0.6. Several users reported that with firmware 1.0.5 there is no such an issue.
I use latest HA and Zigbee2MQTT and I even tried IKEA Dirigera - both gives the same: it exhibits the exact same “stuck occupied” symptom across Zigbee2MQTT, Home Assistant (ZHA), and an IKEA DIRIGERA hub, and because of that the issue is directly tied to the quirks in Sonoff’s Zigbee implementation.
Standard Zigbee motion sensors (like IKEA Vallhorn, Philips Hue, or Sonoff’s own SNZB-03) implement the IAS Zone cluster (0x0500). They send an explicit alarm bit when motion starts, and then send an explicit “alarm cleared” bit when movement stops.
The SNZB-06P implements two clusters simultaneously:
msOccupancySensing(0x0406) -
ssIasZone(0x0500)
Generic hubs like the IKEA DIRIGERA expect a standard IAS Zone motion sensor. The DIRIGERA pairs with it, binds the IAS Zone cluster, sees the initial Occupied bit, and waits for a standard clear report. However, the SNZB-06P handles presence state changes primarily through attribute reporting on the msOccupancySensing cluster, and does not report state clears on the IAS Zone cluster reliably. Because DIRIGERA does not know how to handle the proprietary combination of clusters on this device, it gets stuck on “Occupied” forever.
Can you fix the issue?
Thx, Vlad.
