Slide scenes on ihost
Why on ihost I can’t create scenes with slides, for example if I slide a switch to the right it turns off the living room lights, this is only possible with the ewelink app?
thank guy
The Sonoff integration in home assistant exposes these slide events to home assistant. Currently I use the homeassitant/home-assistant add-on in docker on the ihost so that I can capture the slide left/right events on my TX ultimate switches using home assistant automations.
My home-assistant automation sets virtual switches in home assistant. Then my node-red add-on on the ihost triggers flows using the home-assistant palette to set ihost virtual switches which can be used for automations on the ihost side.
I think the ihost dev team should add support for these slide events to the scenes in ihost as well as the node-red-contrib-ewelink-cube node-red palette.
So you have HA with sonoff integration, and the scene from HA pass to node-red, is correct? Sorry but I’m newbie on this…
Yea, I use the iHost to run an automation to turn on/off everything in a room. Including other devices not supported by ewelink. Stuff like my panasonic tv and meross plugs.
In the iHost I have homeassistant/home-assistant configured under the Docker hub Add-ons. I also had to configure the filebrowser/filebrowser docker add-on too to access the home-assistant files and folders directly. Then in home-assistant I installed HACS and the Sonoff LAN integration.
Sonoff LAN allows home-assistant to control my Sonoff devices on the LAN. Including the TX Ultimate switch’s swipe actions. This allowed me to create a virtual device on home assistant that I can toggle using a home-assistant automation when the slide action is detected.
Then in my Node-Red docker add-on I have the node-red-contrib-home-assistant-websocket palette installed. I have a node-red flow that triggers when my home-assistant virtual device state changes. Then I can do the rest of my automation logic turning devices on/off in that node-red flow as though it was triggered by the slide action.
It might be possible to do all this without the virtual devices but when I figured out how to handle basic switch state changes in node-red from home-assistant i just went with using a virtual switch as my trigger.
All that work just to start my node-red flow on the slide event because it hasn’t been supported in ihost yet but has been supported by the home-assistant Sonoff LAN integration.
Hey, are you referring to the TX Switch series?
Yes I speak about slide scenes of tx ultimate on ihost…
