Scenes in i-Host
Within the i-Host, in the automatic scenes and in the manual ones; it should be possible to choose a time frame in which the scenes were effective.
Speaking of Secen on iHost:
  • When setting conditions (If…) there is only the possibility of “Smart Dveices” and “Timer”
  • As an answer to the condition (Then…), there is only the possibility of “Smart Dveices” and “Delay” - up to 1 hour
I think that this is insufficient… In some future upgrades, it is necessary to consider the possibility of adding:
  • Sunrise/Sunset
  • Manual scenes (Smart scenes)
  • Delay “Delay” times
    as implemented in the eWelink application
You should also look at the possibility of additions:
  • setting logical conditions (Mixed AND and OR, NOT),
  • setting the from-to date as a logical condition
  • the possibility of sending a message in response to a condition in the eWelink application (somewhat with iHost - “SoundAlarm” and “Text to speech”).
Exactly.
Yes, we are also aware of the lack of current scene capabilities, and will continue to add new capabilities in the next few versions to support it to meet more usage scenarios.
I hope it will be soon
Has there been any progress on this?
I have had to use node red to setup a sunset trigger. This is quite an elementary feature , that most would normally expected to have in home automation system.
I cant find a native way to set a simple timer that turns a device off, at set length of time after it was turned on.
Maybe this feature is there but I can not see it.
The sunrise and sunset trigger of the smart scene feature is on our development roadmap. expected to be available in the first half of this year.
