Sunrise Sunset events as triggers of scenes in iHost
When is this improvement expected to be possible?
Greetings
*Moderator edited the title for clarity
What exactly does that mean?
When are the time if sunset/sunrise at any location; then action like on/off one light.
All devices or any smart system can do without problems.
If you’re using Node-red on your iHost there is at least one node, that I know of,
node-red-contrib-suncron
that can give any sort of solar event.
If you prefer to set up scenes in iHost rather than Node-red then create a virtual light in the eWelink Cube node and set that to sync with whatever event e.g. Nautical Twilight that you want. This device will be your trigger.
I guess since you’re talking about iHost you want it offline? I know a method but it requires online. https://sequematic.com/
The best method that works offline in real time. Is to connect a twilight sensor to minir4. Depending on the state of minir4 (on/off) you can build any scenes.
Spoiler alert: it’s coming :wink:
