Hi!
I have the zbridge-p. I know a device has bound to a router because I look at the rssi, and if it is the same as the router, I assume it is attached to it. With the s26 none of the devices was having a gods rssi, but when I added the zbminir2 I saw that the rssi of many of them improved and was the same rssi as the zbmini
I didn’t know about the 10 limit, it’s bad that it only shows in the Web (thought I have not read it anhwhere) and that there is no way to know which devices are attached to routers or bridge. There should be an option to see it
Alex
