📱[Rolling with new releases ]eWeLink App Updates
@emma23 @jonniugr I can confirm the issue with the volume buttons after using the camera view in the eWeLink app. The app keeps the audio channel occupied and thus causing the issue nothing else can be played on the audio channel. A very frustrating issue which indeed can only be solved by killng the app. This issue is one of the reason I currently would avise against eWeLink supported camera’s.
Can you please add my device too?
ID = 100250c266
THank you very much.
When creating a scene, only the on and off option is possible on the smart device, but there is also the reverse option on the website. Why was this feature removed from the application?
The ewelink 6 application is currently only seen as a graphically improved application against the main application. The absence of language packs (despite the fact that Czech is set, everything is in English) and almost zero device support, including the Sonoff device, make it completely unusable in its current state. I understand that it is a test version, but this is very much a test. At a minimum, all currently supported devices should have been implemented, not this one. I have 160 devices, but maybe 10-20 are supported, so nothing can be tested. At most, the installation does not cause the phone to fall or explode, and that has not happened yet. You really have a lot of work ahead of you to make the application usable and at least catch up with the current one.
