Robotic lawnmower and relay to control boundary wire
@andy.wolf I also have the landroid worx m700 plus. are you sure it’s DC? I thought it was a pulse signal around 30VAC
Our lawn is not really suitable for robot lawn mower so I have some areas of the lawn it alwyas get stuck, sometimes after 10 minutes sometimes after 1 hour.
Also Landroid only supports 4 zones and it need to drive along the boundary to get to zone 2-4… So for one of my zones it needs to drive 150m along the boundary or like i have it now I can flip a switch and reroute my boundary wire and it only needs to drive 8m…
So currently my setup I uses 3 way switches, however i would like to automate it. Like monday the switch should be in position A and rest of the week in position B. A switch is basically just a relay, but i dont really wanna run a lot of power cables around my garden, so best option is to power it directly from boundary wire, or in worst case have a battery operated solution.
Here is the location of the lawn https://maps.app.goo.gl/qsSRBehCZrhjj2Gn9
