I’ve a quick question, maybe an obvious one.
I’m adding some lights to a lego I’ve built. They are gonna ship the lights with a power bank which will be inside the lego and power up all the LEDs.
My question is: is there a product from sonoff that can be used to make the whole system working with google assistant? I only need to be able to turn it on and off. Thank you in advance
You may need a relay with dry points, give it a search and you may find solutions
Thank you for your reply, what should I google? I’m a newbie
Something like this would do the trick.
Sorr for the misunderstanding, it should be Relay with Dry Contacts
