2 posts were split to a new topic: [iHost V2.4] Shutters promote to calibrate positions
Yeah, I’m not updating yet! I see there is still issues with the Sonoff TRVs also.
Maybe I’ll chance it on the next update… and maybe not!
I took my brave pill and hit the update button. Let’s see if this update sends me to the medieval times, candles and such.
Are there a lot of candles and such? Any bells? Did the earth tremble?
14 posts were split to a new topic: [CUBE] Allow Certain Device Selectable Multiple Times in IF and THEN
Let’s say I haven’t had much luck with my IKEA smart bulbs ever since firmware version 2.3 (when Zigbee2Cube disappeared from the Pilot Features submenu). It’s been a nightmare ever since. I gave the iHost the benefit of the doubt, thinking the issue might be with Node-RED. But no—it turns out the problem lies with the iHost firmware itself.
Even with version 2.4, there’s this persistent and annoying issue where the bulbs randomly lose connection to the iHost for no apparent reason. Sometimes they lag massively or don’t respond at all.
But the worst experience? One pitch-black morning, I had to drive to the airport, the motorway was already clogged, and I was short-fused to begin with. Then the iHost decided to go berserk. No light in the bedroom, and in the bathroom? A full-blown disco party. Lights flickering on and off, shifting between 50% and 100%, warm and neutral tones—it was chaos. Absolutely maddening.
@ward Can I get the access to the Skunk Works inside Sonoff?
hey,
Sorry for the madness of iHost, can you send us system log for a look?
And if possible could you provide some device id you had issue with?
Thx in advance
This topic was automatically closed 12 hours after the last reply. New replies are no longer allowed.
This scene was done by 3 days correctly, but then it stopped.
Log sent on Feedback 224123
The wifi dont work on my ihost… not even let me search wifi networks… i try the reset a few versions ago but dont work anw
WiFi module is defective. Change it on product warranty.
Thx for your feedback.
In your case, please contact Sonoff for further assistance.
Did you know if smart lock will be managed by matter in the next version ?
For my case I got Yale Leenius 2 https://yalehome.fr/serrure-connectee-linus-l2/?srsltid=AfmBOop0QrxK-hFNIrT5PDyPdZomTVbSEzx-L49zpvCtqtfphRg1ZkE-
And I got an error when try to synchronised. The error said something like device not supported.
Thanks.
ihost does not support matter devices like locks. I suspect that it will not be possible soon. if you want to control the lock via matter, you must use another platform that supports matter (- e.g. smartthings).
smartthings , google home and alexa are currently supporting matter lock
Yes it works with Google home. Thanks for your answers
Merry Xmas everyone
@ward @SuiKa
iHost is flooding the log every minute on Docker → Tile2CUBE-Weatherapi → LOG
The device ID and MAC address below are edited.
2024-12-25T14:41:00 2024-12-25T14:41:00.076Z [INFO] (mod.cube-api) start polling query
2024-12-25T14:41:00 2024-12-25T14:41:00.098Z [INFO] (mod.cube-api) GetBridgeInfo data: {"error":0,"data":{"deviceid":"10020940a1","ip":"192.168.20.100","mac":"d0:27:03:89:41:10","ethernet_ip":"192.168.20.100","ethernet_mac":"d0:27:03:89:41:10","domain":"ihost.local","fw_version":"2.4.0","name":"iHost"},"message":"success"}
2024-12-25T14:41:00 2024-12-25T14:41:00.101Z [INFO] (mod.cube-api) GetBridgeInfo finally result : {"error":0,"data":{"deviceid":"10020940a1","ip":"192.168.20.100","mac":"d0:27:03:89:41:10","ethernet_ip":"192.168.20.100","ethernet_mac":"d0:27:03:89:41:10","domain":"ihost.local","fw_version":"2.4.0","name":"iHost"},"message":"success"}
2024-12-25T14:41:00 2024-12-25T14:41:00.101Z [INFO] (mod.cube-api) localIp and resIp : "192.168.20.100" and "192.168.20.100"
2024-12-25T14:41:00 2024-12-25T14:41:00.102Z [INFO] (mod.cube-api) judgeIpModified no modify
2024-12-25T14:42:00 2024-12-25T14:42:00.076Z [INFO] (mod.cube-api) start polling query
2024-12-25T14:42:00 2024-12-25T14:42:00.099Z [INFO] (mod.cube-api) GetBridgeInfo data: {"error":0,"data":{"deviceid":"10020940a1","ip":"192.168.20.100","mac":"d0:27:03:89:41:10","ethernet_ip":"192.168.20.100","ethernet_mac":"d0:27:03:89:41:10","domain":"ihost.local","fw_version":"2.4.0","name":"iHost"},"message":"success"}
2024-12-25T14:42:00 2024-12-25T14:42:00.099Z [INFO] (mod.cube-api) GetBridgeInfo finally result : {"error":0,"data":{"deviceid":"10020940a1","ip":"192.168.20.100","mac":"d0:27:03:89:41:10","ethernet_ip":"192.168.20.100","ethernet_mac":"d0:27:03:89:41:10","domain":"ihost.local","fw_version":"2.4.0","name":"iHost"},"message":"success"}
2024-12-25T14:42:00 2024-12-25T14:42:00.100Z [INFO] (mod.cube-api) localIp and resIp : "192.168.20.100" and "192.168.20.100"
2024-12-25T14:42:00 2024-12-25T14:42:00.100Z [INFO] (mod.cube-api) judgeIpModified no modify
Sonoff Wireless Smart Switches (TX-Series) are frequently going offline even with an strong 2.4GHz signal where they are.
Docker: eWeLink Smart Home
Log sent (Feedback ID 225008)
