👨‍💻‍【Release Note】eWeLink CUBE V2.5.1 Update
New update, again lost the link with eWeLink app.
I know it is not functional, but at least a quick check that the iHost is online :wink:
This is not listed on the changelog :thinking:
How can I have these readings on IKEA VINDSTYRKA?
I can only see the Temp/Humid
Re-pair the device is needed.
Removed the device and added again…
I still cannot see the PM2.5 or VOC.
It’s showing only the Temp/Humid
Not working for Sonoff SNZB-02D
Current firmware: 1.0.9
Link Quality is 192 (-52dBm)
Battery is at 100%
Are you sure this feature is working?
All my battery powered devices (SNZB-01, SNZB-02, SNZB-02D, SNZB-03, SNZB-04) are at 100%
Some of them are 18 months old
Umnie ota works. I did the ZBMICRO update. Battery devices need to be paired again to update the status.
So if I have 20 devices and many scenes, I need to pair everything again and set the scnes once again?
I can’t believe there isn’t any other smart way to do this :frowning:
I’m also nervous about this. That’s why I won’t do it. There’s a second problem. If you pair the sensors again, then in node-red and homebridge the sensors won’t change state.
Isn’t this a limitation of ZigBee?
I’ve had similar problems with Z2M in the past!
6 posts were split to a new topic: Issue with OTA for SONOFF TRVZB via eWeLink CUBE
That’s odd.
We have the same device and it’s working without any problem.
Can you send your system log via feedback?
We’ll see what’s wrong.
Hey
The fixing plan is merged with another network optimization task ETA next version.
Please see the ID 214212
This bug was not fixed?
I saw the problem today in this new version.
No.
We’ll release a bugfix version within a week or so.
That will contain the fix.
This issue was replicated or am I the only one with this problem?
There’s a potential issue with IKEA devices. Usually, removing the device and pairing it with iHost should solve the problem. If it doesn’t work, please try again.
Thanks for your patience.
