Of course, the eWeLink App is expected to support the addition of Matter bridges in February 2024, and version 5.2 is currently open for adding Matter switches and RGB lights.
Hello,the target issues addressed by iHost version 1.12.4 are the inability to add a Matter bridge and the wrong name after reboot.
We have pushed this version to your iHost, if your iHost does not receive the upgrade alert, please switch to the Settings page to refresh and confirm.
We would like to hear from you to see if we have successfully resolved your issue and thank you for your continued support of eWeLink!
Ciao
with two Alexas no, it doesn’t work but with one Alexa and Nest hub it does, even if it’s complicated.
Ciao
are you sure that the version you indicate exists?
Ciao
HI
with “Nest Hub” it is wrong to send the _ character (underscore character) in the device id through “matter” google home app goes into error.
it would be better to send it like this.
Yes.
However, version 1.12.4 is still in the verification stage, so only designated users can receive it. After confirming that the problem is resolved, we will release the full fix.
Hi ![]()
I cant upgrade to 1.12.4, it wasnt pushed to my device.
I’m currently on 1.12.3.
Trouble you to switch to iHost’s settings page again to refresh and wait for 5 minutes, you will receive the push of version 1.12.4.
Hi ![]()
Tryin’ to refresh but nothing coming up…
Try to reboot and waiting for 5min.
The target issues addressed by iHost version 1.12.4 are the inability to add a Matter bridge and the wrong name after reboot.
So the first time you add the iHost Matter bridge to the Alexa App in version 1.12.4, the name will still be the serial number, but the name will remain the same after you correspondingly change the device name in Alexa and restart the iHost.
If it’s not the above, please submit the syslog to me, thank you very much!
Any good news?
Hi
sorry I had to run an errand.
I just rebooted again and checked but still no 1.12.4 available for download
I’ll recheck tonight. It might needs some time to get it pushed ![]()
Just checked. No 1.12.4…
Hello, I pushed version 1.12.4 to your device again, can you check it one more time?
Hi all.
I can’t upgrade to latest version, the ihost currently is on 1.12.0.
I rebooted the iHost, and nothing.
Got it thanks!
Sorry it took me a while to respond, today I was having Xmas family lunch at home.
So after the update to 1.12.4 I got all zigbee devices names lost again (hopefully last time).
Once I entered them back in Alexa, I rebooted the iHost, and I could keep the names in Alexa.
Is there something special to do to check that it works?
Where should I sign up or pay
to test the new versions??
The eWeLink team has pinpointed the problem and will fix it in the full release this week, so stay tuned.
