I have problem with CUBE on Ihost.
So lately I have to change my router because previous one broken. After change I decide to change a bit. After I change the router I just realize that the Ihost cannot go to Internet but local still ok (I can web console).
After checking, I just realized that the Ihost still use previous lent IP from previous router (it also serve dhcp server). at broken router I was set pool from 192.168.1.10-192.168.1.150 but the new router I change the pool from …1.100 to 1.254. I discover the ihost still use 192.168.1.20 (this IP is alocated to ihost). I check to client list on router, the ihost mac address is not there.
I have try to reboot either router and ihost many times. It still use 1.20
I have no more Idea since cube on ihost doesnt give much tools to analyse.
- no network parameter setting (everyone know, just relay on dhcp)
- I have no os console (ssh), at least I dont know how. simple ssh not open
- I also dont know what parameter is running on the stack make it cannot go to internet. Since default gateway still same 192.168.1.1, even if I just accept the weird IP 1.20 not renew from current dhcp
Second problem, I am start to think about reset, but since It is lot of configuration, I am plan to backup. When I click backup, It looks like doing something, find out at menu restore, I can see my automatic backup, but cannot find my manual backup, while it should be can store up to 4 manual back up. Where is the backup. Or is it not working? if not why.
