Hi All!
About a month ago, I started using iHost. I successfully connected several temperature sensors and a thermostat to it. I set up remote access.
After that, I decided to try Home Assistant. The only problem with it was that it would periodically disappear from the network—the IP address couldn’t be pinged.
I decided to switch back to CUBE OS.
I turned off the power, removed the SD card with HAOS, and inserted a blank SD card. I pressed the reset button and held it down while turning on the power. The indicator turned red, then after about 5 seconds, it turned blue for 1-2 seconds and then turned red again.
I don’t see any activity on the network. There are no DHCP requests. There are no new IP addresses on the 192.168.0.* network.
If I reinsert the SD card with HAOS, HA boots successfully.
How do I reset iHost to factory settings?
Jury
