Paral-sync problem on iHost with SNZB-02D
I have several SNZB-02D sensors, some of them are paired with a NSPanel Pro and the other ones are paired with an iHost. The SNZB-02D paired with the NSPanel Pro are visible in iHost through Paral-sync, except one.
For the one who doesn’t work, when I click on “Sync” in Paral-sync on iHost, I have the following error message: “Synchronization fialed, device not supported”.
Here is the log:
2025-02-21T08:36:59 [2025-02-21T07:36:58.994] [INFO] total - (service.syncOneDevice) willSyncDeviceId: a4800cf436
2025-02-21T08:36:59 [2025-02-21T07:36:58.995] [INFO] total - (service.syncOneDevice) srcGatewayMac: 14:F5:F9:4C:8A:80
2025-02-21T08:36:59 [2025-02-21T07:36:59.007] [INFO] total - (service.syncOneDevice) syncDevices: [{“name”:“Sejour”,“third_serial_number”:“a4800cf436”,“manufacturer”:“SONOFF”,“model”:“SNZB-02D”,“firmware_version”:“2.2.0”,“display_category”:“temperatureAndHumiditySensor”,“capabilities”:[{“capability”:“battery”,“permission”:“0100”},{“capability”:“temperature”,“permission”:“0110”,“settings”:{“temperatureCalibration”:{“type”:“numeric”,“permission”:“11”,“step”:0.1,“value”:0},“temperatureUnit”:{“type”:“enum”,“permission”:“11”,“value”:“c”,“values”:[“c”,“f”]},“temperatureRange”:{“type”:“numeric”,“permission”:“01”,“min”:-10,“max”:60}}},{“capability”:“humidity”,“permission”:“0110”,“settings”:{“humidityCalibration”:{“type”:“numeric”,“step”:0.1,“value”:0}}},{“capability”:“thermostat-mode-detect”,“permission”:“0110”,“name”:“humidity”,“settings”:{“setpointRange”:{“permission”:“11”,“type”:“object”,“value”:{“supported”:[{“name”:“upperSetpoint”,“value”:{“value”:60}},{“name”:“lowerSetpoint”,“value”:{“value”:40}}]}},“supportedModes”:{“type”:“enum”,“permission”:“01”,“values”:[“COMFORT”,“DRY”,“WET”]}}},{“capability”:“thermostat-mode-detect”,“permission”:“0110”,“name”:“temperature”,“settings”:{“setpointRange”:{“permission”:“11”,“type”:“object”,“value”:{“supported”:[{“name”:“upperSetpoint”,“value”:{“value”:27,“scale”:“c”}},{“name”:“lowerSetpoint”,“value”:{“value”:19,“scale”:“c”}}]}},“supportedModes”:{“type”:“enum”,“permission”:“01”,“values”:[“COMFORT”,“COLD”,“HOT”]}}},{“capability”:“identify”,“permission”:“0100”},{“capability”:“rssi”,“permission”:“0100”},{“capability”:“lqi”,“permission”:“0100”}],“state”:{“battery”:{“battery”:100},“temperature”:{“temperature”:21.1},“humidity”:{“humidity”:48.1}},“tags”:{“__nsproAddonData”:{“srcGatewayMac”:“14:F5:F9:4C:8A:80”,“deviceId”:“a4800cf436”}},“service_address”:“http://ihost:8322/api/v1/open/device/a4800cf436”}]
2025-02-21T08:36:59 [2025-02-21T07:36:59.034] [INFO] total - (service.syncOneDevice) response: ERR_CUBEAPI_SYNC_DEVICE_PARAMS_INVALID
2025-02-21T08:36:59 [2025-02-21T07:36:59.035] [INFO] total - (toResponse) result: {“error”:604,“msg”:“eWeLink Cube API - syncDevice error: params invalid”}
Firmware on iHost is 2.4.3.
Thanks in advance,
Nicolas
It’s a known issue due to an update of nspanel pro.
We’re fixing it now, but it’s a complicated issue so not expected to be release soon.
