I sent you the device ID in DM.
Looking forward for that roadmap ![]()
Bonjour pouvez vous me permettre de faire la mise à jour Device ID :1001ed0b08
merci
Could anyone solve the screensaver lack situation for HA companion app ? I dont like that the screen is always on.
Hi, your device has been deployed with the update. Please go to Settings > About to upgrade. Thank you for your support, and feel free to reach out if you encounter any issues.
Hi, your device has been deployed with the update. Please check it through Settings > About -> Software Update on your NSPanel Pro screen. Thank you for your support, and feel free to reach out if you encounter any issue.
@edgardasb @fedpalo @michelangelo.cimino Hi, regarding the previously mentioned issue of unstable disconnections with the TRV’s external temperature/humidity source, we have identified the root cause. The fix will be included in the v4.0.10 update scheduled for release today. Thank you for your patience and valuable feedback.
While you’re at it, please check why, when I select the temperature sensor panel for display - one that reports only temperature - the screen still shows relative humidity. Naturally, the value is empty and displays as --%RH, which makes no sense.
Also, once again I encourage you to bring back the previous screensaver design (digital clock) from earlier versions. In 4.x, the digits are noticeably smaller and therefore harder to read from a distance. An ideal solution would be to allow users to choose the font size.
Hello, can you please add my devices?
DEVICE 1 ID: 100250c764
DEVICE 2 ID: 1002375d29
Thank you
I have the NsPanel pro 120 and since update to 4.0.0 and 4.0.7 the device not connected on my zigbee network (with Zigbee2mqtt).
I use the router mode.
Odb is unlocked
Dear Sir,
I just bought a NSPanel Pro 120 but it came with App and System version 3.12.0 and as I am starting to build my ecosystem now I would prefer to start with the latest version possible.
Although when I check for newer versions I get the message I am already up-to-date.
Is it possible to include ID 100250deee on the update list?
thanks and regards,
MA
Please refer to my reply to your question on the other post: NSPanel Pro 120 - Ver. 4.0.4 Zigbee Devices Issues - #5 by MichaelLearnsToCode
Hi, the firmware has been deployed for your devices. Please navigate to Settings → About to check the update. Please let me know if you met any issue.
I just discovered another issue with recent NSPanel Pro update.
Thermostat. Manual setting. Device set to stay off when thermostat is turned off.
Situation:
1 - heating device is working - destination temp set to 25C - but at 23C I changed my mind
2 - I turn off thermostat - and thermostat is disabled - but heater stay on
Please investigate this.
Sorry for the issue. Please submit a log on the NSPanel Pro device through Top drop-down menu -> Settings -> About -> Feedback -> Submit
Hi, thank you very much for trying out v4.0.x firmware.
Your NSPanel Pro 100250deee has been added to our OTA whitelist. Please navigate to Settings -> About to check the update on your NSPanel Pro screen.
Main id: 10022e4d55 , second device id:100265651 thx for adding to group with latest firmware 4.0.x.
Main id: 10022e4d55 , second device id:100265651a
Your devices have been added to our OTA whitelist. Please navigate to Settings -> About to check the update on your NSPanel Pro screen.
thank you
Would you please submit a feedback on eWeLink App through Profile -> Help & Feedback -> Feedback -> Submit Feedback.
