NSPanel PRO -> Thermostat: temperature accuracy +- 0.1 °C
Currently, the accuracy is ±0.5 °C, which is definitely too much. In my opinion, it would be good to be able to set it to ± 0.1.
The same applies to the target temperature, which can be set to 0.5 °C, and it should also be possible to set it to 0.1 °C.
Thank you very much for using NSPanel Pro. We are sincerely appreciate your valuable feedback.
We were busy rolling out V4.x App for NSPanel Pro. This version has been completely rewritten in Kotlin and it should provide much better performance and stability.
We will work on your suggestion ASAP. I will keep you posted on this feature.
