I’m using the thermostat from NS Panel but unfortunately the temperature accuracy which can be set is +/- 1 degree which is creating a discomfort as practically will be a difference of 3 degrees between start and stop of the heating system . Can be updated to have a temperature accuracy of +/- 0.2 degrees?
Or there is any solution to reduce the difference between start and stop temperature?
Thank you in advance!
This has been raised many times and seems to be a hardware issue. Best to contact Sonoff, I have already
Is there a way to bypass this issue using an external temperature sensor with more accuracy? or ns panel will only allow +/- 1 degree steps?
New firmwar about to be launched.
In the mean time I use another device / scene, which will shut of the heater earlier
Oh !! new firmware is great news, hope it deploys ASAP !! thanks for the info !!
finally! the update that we ALL wanted! now we can change temp accuracy by 0.5
