NsPanel Pro request features
Dear Ewelink Team ,
I would suggest adding some needed features to NsPanel Pro as the following :
1- adding an option to ewelink app to reboot nspanel remotely as we do with sonoff camera for example
2- being able to use wifi and matter devices into smart security built in system
3- syncing matter devices from and to Ihost vice versa
4- showing matter devices as sub devices to panel
5- removing the word (new) from theme and reminder icons , because we already pressed these icons but the word new still there
6- add an option to add camera’s to nspanel from ewelink app itself because it will be much easier
7- adding an option at ewelink app to fully configure the nspanel remotely since its easier to do on mobile than on panel screen
8- allowing ota updates while screen saver on
9- adding an option to be able to call from panel to mobile , not just panel to panel
Many thanks in advance
We now allows mannualy check update from the NSPanel Pro side
For UI-related questions, we will soon have some big twists to it.
For other feature requests, I will share them with our product team.
Thx
iHost should act as a Matter Hub too later this year if everything goes well; there’s no such plan to sync devices between at the moment.
Strictly speaking, they are not sub-devices of a specific NSPanel Pro; if one loses connection, another eWeLink matter hub will pick them up, including the CAST app.
@ward matter presence sensor with light intensity sensor. When will nspanel pro be able to read the light intensity value from the matter sensor?
i got light sensors too , smart lock , smoke and leak detectors , vibration sensor
There’s no such plan yet
Smoke and leak detectors are from Matter 1.2 and 1.3 spec. We won’t expect updates that soon.
Matter spec does not support the vibration sensor, and there is no rumor it will be supported in upcoming Matter versions.
I hope that IHOST will soon be able to launch MATTER HUB. What is missing now is direct control of Matter devices from the IHOST interface. I have to create virtual devices and connect them in the smartthings application.
Light sensor - measurement of light intensity comes from matter 1.0.
We need such a function.
Google home and smartthings already have this.
Team ewelink.
** What new features will we see in 2025. **
Will we one day see a feature where nspanel will function as a video intercom. The camera image will be displayed automatically when triggered by a motion sensor or switch.
that would be great!
