NS panel pro - zigbee devices
Welcome to the SONOFF NSPanel Pro category!
Hi everybody!
I’m not able to sync my zigbee devices to be seen from ihost and NS pannel pro at the same time.
I have ZBMINI R2 for lights that were added by NS Pannel pro and can not be synced in my ihost
If I click in sync, appear this message
Yesterday I added one device MINI ZBRBS with the ihost (from the computer, and I can not see it in the NS pannel pro and therefore I can not manage it from the NS pannel pro, only from the website in ihost
How can I see zigbee devices from ihost and ns pannel pro?
Thanks!
Unless I’ve missed something, the ZBMINI R2 hasn’t been listed in any official source as compatible with Paral-Sync. Paral-Sync supports the ZBMINIL2, but the ZBMINI R2 is a different version - older, less advanced, though still Zigbee 3.0. Synchronization via Paral-Sync requires the device to be locally added to the NSPanel Pro and to be compatible with its firmware and Zigbee stack.
It seems that in this case, a hardware upgrade will be necessary :roll_eyes:
What do you mean with hardware upgrade?
Mini-ZBRBS is also old? It has just appear in market
I want to change all my sonoff dual R3 because I don’t like to use wifi devices. I have many connection issues (4002)
What do you recomend me for the lights and for the curtains(motor) with connection different to wifi? Which device?
Nope, quite the opposite! I was talking about the ZBMINI R2.
The Mini-ZBRBS are probably still too fresh, not yet on the party list. These things have happened before. Most likely, in the heat of launch-day excitement, they got swept up by the shiny new release and forgot all about Paral-Sync. Hopefully someone from the staff spots that forum thread soon and clears things up before we all start reverse-engineering new Zigbee toys :slight_smile:
@bustavin Why don’t you add all your Zigbee devices to ihost. Then send them through Matter Bridge to NSPanel Pro.
Paral-sync is an old add-on that is no longer being developed.
This topic was discussed a long time ago.
you will do the same in ihost, but for ewelink nspanel pro.
Thank you for your fedback
don’t forguet the target of these thread, which is to program scenes from ihost with all zigbee devices, and also at the same time to create manual buttons in NS pannel pro to be able to perfom actions manually with these zigbee devices
Example, the idea is to program lights with sensor presence in ihost and put buttons in NS pannel pro to switch on/off manually when needed
Back when I was a moderately satisfied iHost owner, meaning hope only lost to experience once a week. this kind of setup didn’t quite work. The eWeLink/Sonoff architecture politely forces you to choose: either NSPanel Pro as the main Zigbee hub, or iHost. You can link them partially, but full symmetry? Only in your hopes. The Paral-Sync add-on offered some relief, though more like a band-aid than a cure. So after nearly a year, I decided to head toward Home Assistant, and despite a few limitations, it was the right move for my sanity.
Just to be clear: I still use over 30 Sonoff devices and occasionally buy new ones. Because, as we all know, most of Sonoff devices are an excellent choice as far as hardware, design and price are concerned. And as for the software limping along… well, that can be fixed, though sometimes it takes an impossibly long time. One might say that’s part of Sonoff’s irresistible charm: the thrill of waiting, the suspense of rebooting, and the occasional joy when things actually work :upside_down_face:
SONOFF MINI-ZBRBS Zigbee does not stop when it reaches the end of its travel or continues to power the blind at the beginning.
When the Dual R3 model raises the blind, the relay stops powering the blind, but the SONOFF MINI-ZBRBS Zigbee does not.
Today I returned two, both of which worked the same way. I will wait to see if they fix the R3 Dual Wi-Fi disconnecting the relay when the blind is raised or lowered.
The ZBMINI-RBS device is designed to work with a motor equipped with a limit switch. The relays are only deactivated when the motor is stopped by the limit switch. This ensures that the roller shutter will always close completely, even if it becomes decalibrated.
What do you mean with use Matter Bridge to NSPanel Pro.
Is it a different add on to syncro devices in ihost and NS Pannel pro?
Hi, sorry for the issue.
First, let me confirm what you want:
  1. Add Zigbee devices (such as ZBMINI R2) to NSPanel Pro.
  2. Using Paral-Sync Add-on running on iHost to sync these Zigbee devices from NSPanel Pro to iHost.
  3. Control these Zigbee devices on iHost (Dashboard, Automation, etc.)
By the way, Paral-Sync Add-on can only sync Zigbee devices from NSPanel Pro to iHost, not the other way round.
Hello!
Thank you for your feedback!
What I need is to create manual scenes in NS pannel pro to open/close curtains or switch on/off manually, and, at the sametime, for this smart devices, to create automatic scenes to open/close curtains or switch on/off lights with sensors.
I have zigbee devices like MINI-ZBRBS and ZBMINIR2, in which I had to sync from ewelink app to be able to create manual scenes.
For ZBMINIR2 i have created manual scenes in ewelink which are visible in NS pannel pro but I can not sync devices in ihost with paralsync. No way to create smart or automatic scenes in ihost
For MINI-ZBRBS I’m not able to do anything when I sync from ewelink. No way to create manual button in NS pannel pro, no way to manage from movil app, and no way to see this device trough paralsync
From you points:
  1. Add Zigbee devices (such as ZBMINI R2 and MINI-ZBRBS) to NSPanel Pro. YES
  2. Using Paral-Sync Add-on running on iHost to sync these Zigbee devices from NSPanel Pro to iHost. YES, BOTH
  3. Control these Zigbee devices on iHost (Dashboard, Automation, etc.). YES, AND ALSO TO CREATE MANUAL BUTTONS IN NS Pannel pro
Maybe there are other options no do my needs with a different add-on
Thank you in advance!
From my understanding, you could just add Zigbee devices to NSPanel Pro and manage them using eWeLink App. You should be able to create manual scenes in eWeLink App and add them to the screen of NSPanel Pro.
So for you, ZBMINIR2 works, but not MINI-ZBRBS, right? I will check this with my colleague immediately after Chinese National Day holiday.
If you want to control the devices in your eWeLink account from iHost, why don’t you install eWeLink Smart Home Add-on which will export all the devices (including Zigbee devices added to NSPanel Pro) in your eWeLink account to iHost.
Thank you very much for your feedback.
I look forward to your supoort to solve the issue
Related ewelink smart home in ihost, it’s only working with wifi devices. I don’t see zigbee devices like ZB minr2
The only way to see them in ihost is with paralsync, but sync is giving error always
Best regards
Hi, thank you for your patience.
For MINI-ZBRBS I’m not able to do anything when I sync from ewelink. No way to create manual button in NS pannel pro, no way to manage from movil app, and no way to see this device trough paralsync.
We have confirmed following results:
  1. MINI-ZBRBS can be paired to NSPanel Pro directly. If you met issue on this, please let me know.
  2. If you pair MINI-ZBRBS to other eWeLink/SONOFF Zigbee Hub (such as ZBBridge-U/-P), it can’t be synced to NSPanel Pro. This is a bug, and this is your case, right? We will fix this bug ASAP. At the same time, is it possible that you re-pair MINI-ZBRBS to NSPanel Pro instead of ZBBridge-U/-P?
Yes, this is true and now we think it is NOT a wise decision. We will release a version of eWeLink Smart Home Add-on before October 17th (next Friday) which will export all Zigbee devices of NSPanel Pro to eWeLink CUBE OS on iHost.
Currently, this is the fastest way for us to enable you using Zigbee devices from NSPanel Pro on iHost.
Please let me know if you have any other requirements.
Hi, we have just released a new version of eWeLink Smart Home Add-on for eWeLink CUBE OS on iHost. Now users could be able to export all Zigbee devices from NSPanel Pro to iHost. Please check it out.
Hi there! Based on valuable user feedback, we’ve just released the optimized v4.0.7 today, which includes the following fixes and improvements:
  1. Added support for MINI-RBS
  2. Fixed remote temperature/humidity source issue for TRV
  3. Resolved control abnormalities with some third-party Zigbee devices
  4. Fixed device card list display issues in certain time zones
  5. Improved UI display for temperature and humidity devices
*After upgrading, please verify that both Settings → APP Version and OS Version show 4.0.7. If not, please continue the upgrade process.
If you encounter any issues, feel free to report them in this post at any time. We will address your concerns promptly or release a fix as needed. Thank you for your continued support of NSPanel Pro!
Thank you very much for your prompt support.
I will check in next days and give you feedback.
Hope all these things will be usefull for everybody
Best regards
I installed version 2.6.1 of the ewelink smart home add-on.
Zigbee devices added to nspanel pro are now visible in ihost, but they cannot be controlled.
Zigbee device status not updated in IHOST menu.
Feedback: ID254832
Hi, could you please provide the following to assist with troubleshooting:
  1. The logs from the eWeLink Smart Home add-on.
  2. Your NSPanel Pro device id.
Thank you for your cooperation!
