Hi everyone ![]()
With CUBE OS and its built-in Matter Bridge, you can now bring your eWeLink LAN devices, Zigbee devices, and more into Apple Home. This gives many older WiFi devices a second life - they can now join ecosystems like Apple Home without relying on the eWeLink cloud, and be controlled through Apple Home, Siri, HomePod, Apple Watch, and other Apple ecosystem entry points.
Weâve created this thread as a master post to guide you through the setup process and share device-specific experiences. Over time, weâll keep updating this post with links to individual device tests so you can easily check compatibility and Apple Home features.
Step 1. Add Devices into CUBE OS
- Install eWeLink CUBE OS on your preferred host, check these Installation guides.
- Zigbee Devices: Plug your Zigbee Dongle into a USB port and pair Zigbee devices in CUBE OS.
- WiFi Devices: Install the eWeLink Smart Home Add-on from the Docker tab in CUBE OS.
- Log in with your eWeLink account and sync your LAN devices.
- Youâll see the synced devices appear in CUBE OS and can assign rooms or rename them.
Step 2. Enable Matter Bridge
- In the CUBE OS web UI, click the Matter logo on the sidebar.
- Enable the feature â a QR code and setup code will appear.
Step 3. Pair with Apple Home
- Open the Camera app on your iPhone/iPad and scan the QR code.
- Tap âOpen in Homeâ and follow the prompts.
- Once added, you can rename devices and assign them to rooms.
Step 4. Control with Siri
Once devices are added, you can try commands like:
- âHey Siri, turn on the living room light.â
- âHey Siri, switch off the TX in bedroom.â
Device Experiences
Hereâs a summary of how different devices behave in Apple Home through the CUBE OS Matter Bridge. This table will be updated continuously with new device tests.
| Device Type | Link to Post | Example Model | Rename Device | On/Off Control | Dimming / Brightness | Color Temp / Color Control | Room Assignment | Automation (Trigger/Action) | Siri Control | Notes |
| Switch | Read more | SONOFF TX | - | - | Switches in Apple Home support multi-channel splitting and âDisplay Asâ options, which affect how the device is shown and controlled by Siri. | |||||
| Light | View Video | SONOFF B05-BL | Supports dimming and color control | |||||||
| Plug | Read More | SONOFF S40 | - | - | ||||||
| Sensor | Read More | SNZB-0xP | - | - | - | - | Can trigger automations |
Next Steps
- Weâll keep adding more device experiences (plugs, lights, sensors, gateways, etc.).
- Feel free to share your own tests in the comments-your feedback will help improve the Matter Bridge and guide compatibility work.
If you donât have any Zigbee dongles, please check this giveaway event:
