Hi, I moved my DHCP server so the iHost went from IPv4 static 192.168.0.x to static 192.168.1.x. Adjusted the NR server settings from my old IP v4 to new IP v4. Didn’t get asked for a new token. Setting seemed happy but no devices worked. Made a new server with a new token. Then redid all device nodes.
Was there a way to force it into getting a new token that would have saved me an hour of work changing each node manually to the new server?
