An error occurs at the “event-state” node in Node Red (ewelink cube)
-I use the “control-device” and “event-state” nodes
-I get the token from iHost
-Everything works correctly (on/off with “control-device” and receiving data from iHost with “event-state”)
-If I stop/start iHost (reboot), the “event-state” node no longer works (I no longer receive data from iHost)
-The “control-device” node still works correctly.
I think that the “event-state” node loses the token if iHost is rebooted
