Continuing the discussion from Share a scene:
I wish to share a SONOFF switch using NFC tag but I do not want others to have option of adding SCHEDULE or TIMERS or LOOPS. Is it possible to disabled these features when sharing to others?
The facility to customise sharing and prevent users changing timers, schedules, etc… is excellent. Can you also facilitate sharing a scene such as sharing and NFC tag, so that we can share to a user who cannot trigger the device on the Smartphone but must walk to the tag and tap with the NFC phone tag. This will prevent users opening a door when they are not present at the door.
NO, the NFC tag call the control of the devices is communicate with it based on the App, if you share a tag, in the meanwhile, you’re sharing a device actually.
How do you share a tag without sharing the BASIC SONOFF switch so that the switch can only be activated at the tag using nfc?
Thanks.
There is no way to do that.
Can this be proposed for development team? If the sharing of the BASIC SONOFF switch can be hidden so as to prevent remotely triggering the SONOFF switch, then the SmartPhone can be used as a personal swipe card and ensure the user is located at the Tag or Door location. How can this be proposed for development advancement?
Thanks,
