You have to give the option for more delay. user will use the delay needed. You can NOT put a delay after other delay, so delays over 1 hour are not possible. The same for offset. let user choose the time
Hi there, thank you for the suggestions! 1. It needs to optimize the UI. I will make the suggestion to the team. 2. Reordering the triggers or actions is already on the list, will consider putting them a higher priority. 3. Would you please provide me with the device ID? Because different device types need to be integrated into eWeLink Web one by one, let me check if they are supported on eWeLink Web or not. 4. We optimized part of the power of TH 10/16 in scenes, now they can be set as one of the actions. The next step is to make them can be set as trigger and action at the same time. Please stay tuned with us. 5. Need to choose Delay more than 59 min: 59 s, can you tell us what the actual application scenario of this requirement is? 6 OFFSET more than 30 min-- can you tell us what the actual application scenario of this requirement is?
I second the delay timer needs to have hours too. A few scenes I have I want a light to turn on for 2 to 6 hours and it’s very annoying to do all the programming, on delay off on delay…… just to get it to stay on. Plus light flashes every hour.
Yes Please Allow the reordering of AUTO SCENES or AUTOMATIONS. So they can br grouped together. It is very confusing when you have many of them. You have to scroll up and down alot. I would really appreciate this to added to next app update for android or ios
Thank you
Hi, I need a longer delay (more than 59 minutes) as well. I connect the socket to a clothes dryer and I need to leave it for 4 hours once I turn it on. Come on guys
