Good morning,
ewelink doesn’t know about brightness sensors, so I’m trying to do it using Tuya. In Tuya I have 2 scenes, if brightness then switch (Tuya) on or off. That works.
In the next step I use two processes in Google Home. If Tuya switch is on or off then Ewelink Switch on or off. That also works.
A scene in Ewelink, if movement then light on works. The same scene supplemented with the switch, i.e. if movement and switch on then light on, works unreliably. Then I tried it without the Ewelink switch, created manual scenes which activate or deactivate the scene (if movement then light). I start this scene via Google instead of the switch. It runs, the scene (if movement then light) is correctly displayed as activated or deactivated.
But regardless of this status the light is switched on or not. It seems random.
Where is my mistake?
