Irrigation product SWV UI problem
I’m experiencing an issue with my irrigation SWV devices. Some of them show as “open” in the app even though they are actually closed. What could be causing this?
In addition, I sometimes get a “no water” warning even when there is clearly water in the system. I’m having trouble understanding why this is happening.
There is more done wrong there. Why did they put options like single irritation / circle irritation if it is not possible to use in scenes. Do I really have to open every valve manually and turn on the mentioned options?
Yes, there are many problems. For example, you manually enter a timer and turn on the water, but when the timer is up, the valve doesn’t close. It continues watering. This is very untrustworthy and not environmentally friendly.
I use smarthings to detect rain, it turns on an ewelink switch and i use this switch in irrigation scense. Works great already couple of years.
This problem has been going on for a long time, they probably don’t even have the interest to solve for ever.
