iHost (LAN) & SWV
  1. List item
    When adding IHost, the status “R” appears, and when working with SWV, the status “E” is displayed. M. B. Is this why the problem described in paragraph 2 arises?
  2. List item
    I also connected the SWV directly to the IHost (LAN), and in the Apple Home kit, using the Homebrige docker, I do not see the SWV device in the Apple Home, the SWV does not appear in the Apple HOME.
Thank you for your questions.
  1. The status “R” indicates that the device is a router. Once the SWV is added to iHost, it will change to a terminal device, represented by “E.”
  2. Currently, the SWV is not included in the list of devices supported by Apple Home, so unfortunately, it cannot be integrated at this time.
SWV is not included in the list of devices supported by Apple Home. Sorry. Are you planning to include SWV in the list of supported Apple Home devices? Or is there an incompatibility between SWV and Apple Home?
It is in our plan to make SWV appear in the Apple Home device list through the Matter Bridge function. This will take some time, and is expected to be in June or July.
It is a pity that the acquisition of IHost turns out to be an irrational purchase, since it is necessary to make another duplicate purchase (possibly in the future also irrational) of Bridge Matter.
