If Push notifications are activated and the scene is saved. It is deactivated again and saved. After doing this, they can be activated and deactivated manually.
But it is tedious to have to do this with all scenes. It is something that needs to be fixed.
Regarding point 1, I discovered that:
after having done what I just indicated, the scene with new can be saved.
Thank you for sharing your findings. Yes you are correct if ‘Remote Features’ in the Pilot menu is activated and Push notifications activated in the scene and the scene is saved then the manual enable/ disable will function correctly. It will still function correctly if ‘Remote features’ in the Pilot menu is subsequently de-activated. After going through this procedure the scene can also be successfully edited and duplicated. However I note that scenes that were created before the software update and processed under ‘Remote features’ detailed above do not work. I agree that it is something that really needs to be fixed.
