iHost Docker Container won't load (sometimes CPU 100%)
One of my iHost problems is that Docker Containers just won’t install. The spinner turns. The tf card keeps showing the same storage. In the beginning there is a bit movement. If I move to a different section (for example settings screen) and back, the storage will have changed a bit. But eventually it is just stuck. After hours, restarting the iHost (manually) might help with progress, but it keeps being stuck.
There is a constant error in the Docker logs. But I don’t know, if this is related:
[ERROR] default - dockerSocketClient 9ff0f41c-023b-4fb0-9517-75a0bfe32b2d wrapErrorCallback error Error: connect ENOENT /var/run/docker.sock
    at PipeConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
  errno: -2,
  code: 'ENOENT',
  syscall: 'connect',
  address: '/var/run/docker.sock'
This is obviously related to issues with certain tf cards. Look here for details:
I will mark this as solved. Thanks
