Every time iHost is updated, Docker add-ons (eWeLink Smart Home, Paral-sync) stop working. A reboot is required.
The same behavior is after manual backup and after some unexpected power outages.
Is there any service that controls their work?
My Node Red server restarts after an upgrade. It sounds like some docker images automatically run and some don’t.
The problem is that I can’t run images without rebooting.
hey
will this issue persist? or will disappear after a single reboot only after upgrading?
This issue disappears after manual reboot. But with the next upgrate it appears again.
Hey,
After the upgrade, there should be a reboot, and iHost will fully restart when the indicator LED returns to solid blue and you hear the sound from its built-in speaker. Is it possible that you’re seeing the addons not loaded because iHost hasn’t finished booting yet?
If not, please share some logs with us so we can further investigate your case.
No, unavailability is not related to waiting.
Sent logs via https://help.ewelink.cc/hc/en-us/requests. Ticket 219968
After I sent the logs, I saw that iHost stopped seeing the TF card. As a result, the add-ons stopped. After the reboot, they started. If additional logs are required, please let me know.
same problem…
Dose the issue still there with the new update V2.3.3(staged rollout)?
Let me know and logs attached would be much appreciated.
After upgrading to version 2.3.3, the packages started, it is good. I’ll be watching.
Packages also cannot be started manually until the iHost is restarted.
The same is here…
We can’t find your feedback.
What’s the ticket number?
Ticket 219968. I also sent you a link to the logs in a personal message.
Were you able to find the cause and fix the error?
