I-host and Zigbee Bridge pro
Hi! I am installing i-host with Cube to be independent from the cloud and work local; van i add my formerly used zb Bridge pro to the i-host and use the to the bridge connected devices also use locally? And how should i connect the bridge, just as any other device? Thanks for helping me out!
It worked similarly for me but with iHost to nspp. It works locally but it is questionable whether it will work because it stopped working for some people after a certain update.
I have tried to add it manually, but I have only found the possibility of doing it through Labs > Turbo. It doesn’t detect it and then I try to configure it with the /dev/ttyACM0 and /dev/tty/USB0 ports.
In protocol stack I have tried ezsp and deconz. In baud rate with 115200 and in flow control I have selected hardware.
With none of the configurations I have been able to detect it.
Impossible through the Settings menu because I don’t get any possible option to configure Zigbee.
I am sorry to say that you can’t add ZBBridge-P to eWeLink CUBE OS directly. ZBBridge-P is designed to connect to eWeLink cloud. However, you can add ZBBridge-P to CUBE OS indirectly by using eWeLink Smart Home Add-on which can be installed through CUBE OS’ Docker function.
then it would be better/nice to use a router/dongle instead of the ZBBridge-P being a more direct way for communication. SO I have a second-hand ZBBridge-P, somebody interested :wink:
