How to add Sonoff Dualr3 to Sonoff iHost?
Please follow this guide:
eWeLink Smart Home add-on:
Thanks for the reply. I’ve already done all this and made sure that my DualR3 is LAN enabled in the app. I still don’t see it on iHost.
Please try to refresh the device list of the addon, be sure that the DUALR3 is on the same LAN of iHost.
Or you can try to logout and login the eWeLink Account of the addon to see if the device appear.
I’m having the same problem. My iHost is connected to my Internet provider’s router using ethernet, obviously, and all my devices are connected to a Google Nest router that is connected to my provider router using ethernet too. All of them are in the same LAN (192.168.x.x).
My “eWeLink Smart Home” docker can’t see any device, even after refresh, and I can log on my eWeLink account from docker.
“LAN enabled” devices must be in the same scope network difussion where the iHost is located?
Thanks in advance
After the last Docker version (version 2.3.1) upgrade all my devices appeared in the app. Thanks for your support!
re log in and refresh didnt help , forgot to mention that I use it in meter mode
