Hi there. Thanks for your swift response. Already updated my app to latest version and it works wonder. Now my wife and I can both use eWelink on Carplay. Thanks for for your response ![]()
Você poderia gravar mais videos de outraa cenas? Consegue mostrar ligando uma luz?
Hi Teki,
could u tell any date that this update should happens? As Ahmed, i bought a advanced plan for a family member and couldnt use the carplay coz of shared device.
Another question about this … Since i cant use the shared device, how i can cancel the current subscription? I would like to subscrib when this function is avaiable.
Hi, it is already available in eWeLink APP v5.5
did you share the whole eWeLink home by adding members to the home? if the members join the home, they should be able to select Scenes you created in CarPlay.
make sure your eWeLink APP version is V5.5 or higher
Hi there, this update is available on the eWeLink app(iOS V5.5.0 and above).
The manual scenes need to be created first by your account and then shared with another account via the Home Sharing feature. Here are the steps for Home Sharing:
Step 1. Creates manual scenes with your account first.
Step 2. Once the scenes are created, you can share the scenes with another account using the Home Sharing feature. (your account > Profile > Managing Sharing > Share the home(where the scenes are located)).
Step 3. After the scenes are shared with others, the account should be able to see and select them in the CarPlay function.
Hi all
Have the exact same issue with shared account that can’t create scenes
App is already updated
hi,
members cannot create or edit scenes, they can add existing scenes to their CarPlay.(Advanced Plan required)
Hi, I am using the ewelink function through carplay to control my garage door. However, I can not share the function with my wife for her car. If I log her into my account it logs me out of mine. If I share the home with her she can use the scenes on her phone but not on car play. It would be usefull if when you share a home the other person can use carplay/android for that scene so that we don’t have to keep buying multiple annual accounts.
Maybe we should concentrate on the other items and make them work first, without disconnecting all the time … before creating new junk that does not work.
Sorry to say. Thread and matter is just too buggy. Maybe the next generation devices will work.
Awared, a family plan is under consideration.
Hello Yitie, I have some shared device that I want to activate on Carplay. But it seems not possible to add them to carplay. I tried to create a scene; but same problem, I cannot create a scene with a shared device. I am using the latest version of the App on IOS (V5.6)
For now, secondary account (home member) can control shared devices, run the shared scenes, but cannot edit them.
If the secondary account (home member) wants to use the CarPlay/Android Auto, Advanced Plan is required too, and can only add the existing scenes created by primary account to CarPlay/Android Auto.
We are considering adding other plan like Family Plan in the future.
Hello Teki,
In my case there is no secondary account, just the device is shared between 2 Premium accounts, I cannot add a shared device (owned by another account premium account) to a scene or to Carplay.
I don"t believe there is a way to share a scene between 2 premium account. Can you confirm?
Do you have another workaround to add to carplay a device which is shared by another premium account ?
Thanks,
Hi, have you added the second accounts to the main home?
if not, please go to eWeLink app - Profile - Manage Sharing - your home - Add People, invite the second account to join the home.
once join, the second account can add the scenes (created by first account) to CarPlay/Android Auto.
Perfect, it works.
Any idea when i will be able to use Webhooks scene on the IOS Apple APP?
