[eWeLink CUBE] Select Matter devices to export
The Matter bridge from eWeLink Cube is an awesome feature, but it has a problem: it automatically exports all devices connected to iHost, even those I don’t want to be exported.
It a problem in some cases, for example, I have some Sonoff M5 Matter devices connected directly to multiple platforms and also to iHost through the eWeLink LAN integration.
If I use the Matter bridge from iHost, it re-exports my Sonoff M5 devices to all platforms, causing them to be duplicated!
So, please, create an option to select Which devices must be exported!
unsync M5 device by ewelink smart home addon.
add m5 matter device directly to ihost hub matter.
then M5 device will not be duplicated.
( But I am not sure if ihost hub matter supports M5 matter?)
It uses On/Off Plug-in Unit so it’s supported.
