eWelink Cast RTSP Camera View
I added a camera with rtsp feature to NS panel pro. I can play it here. So how to add a camera with rtsp via cast? Does anyone know?
Aha, it’s a really a completed question, the NSPanel pro can get streaming from RTSP cameras by get the video stream totally locally, but the cloud CAST cannot to do so.
There are two ways to make a work around,
the first is you need to set up a feature we provided name the CamSync, you can refer to the tutorials here,
and the second one is if you have a iHost that you can add a RSTP camera just like to add it to the NSPanel pro and the streaming from local CAST dashboard.
I have configured rtsp Hikvision cameras in camsync camera gateway but those cameras can’t be streamed from cast… Is there any way to do that?
Cameras on Camsync are supposed to be viewed on WEB & configured on CAST tap, can’t see them on the WEB?
In my case, cameras of different models from Reolink, I see and manage via RTSP on the web and in any third-party application, while with Camsync it tells me not supported :face_with_peeking_eye:…and yet .rtsp is a standard and simple protocol…
Solution?
Cameras through gateway appears as option to add in dashboard creation but when you click to add like any other element… Nothing happends. And in ewelink web gateway cameras are marked as not supported yet. Bad luck untill now
Rtsp stream from camera gateway I can see from ewelink web app… But I can’t add to any dashboard
Could you please attach the screenshot of the cast creation page?
gateway cameras on WEB are not supported in scene section, I’ve forwarded this as a feature request to the team, and we hope this compatibility can be improved in future updates.
Now i can see an update allows viewing cameras in cast dashboard, but can be usefull if more than one camera (al least 3 max) can you see at same time
5 months have passed and still with 3 cameras previewed in cast, only 1 can show the image at the same time
