Add your local IP camera to eWeLink cloud via iHost
eWeLink Camsync (Camera Gateway) is a docker image that can be installed on Linux or Raspberry Pi, converting your old security camera that only supports RTSP video stream to WebRTC live stream, allowing you to watch the camera’s live stream on eWeLink app, eWeLink web, Amazon Echo Show and Google Nest Hub.
If you have an iHost, you can install and run the Camsync under docker menu.
Here’s a tutorial video:
If you’d like to run it on Linux, here’s another tutorial:
Where has the CamSync add-on gone?
the name is mediagate
Thank you. Will try later again.
Brilliant. It worked. Thank you.
