Problem: Adding Multiple IP cameras via RTSP
I’m trying to add 4 different cameras directly from my DVR to the iHost, in order to use them within Cast.
However, when adding them manually via RTSP, I’m only able to add my first camera. After that, even if I change the channel, it says the device already exists. Is there any way to work around this?
Please see the attached screenshot showing the issue.
The URL I’ve been using is:
rtsp://username:password@192.168.1.50:554/cam/realmonitor?channel=5&subtype=0
P.S:But I don’t want to use it via docker as eWeLink Camsync. (I’ve already tested it with same URL and it worked).
Thank you for your question! Regarding your issue:
  1. Each camera’s RTSP link should be different (for example, differing usernames, passwords, or IP addresses). Please confirm that the links you are entering are correct and ensure they are not the same as the first camera’s link.
  2. If you have entered different and correct RTSP addresses and iHost still prompts an error, please provide the iHost system logs after your attempts.
Best regards,
Kway
Wouldn’t it be possible to change the logic? Sometimes we want to install cameras that are physically connected to a DVR and we can only configure one camera to the iHost!
Wouldn’t it be possible to change this logic?
I tried to connect several RTSP cameras, but none of them worked. A gray frame appears and that’s it. On VLAN and ODM they all work, but on iHost they don’t. The cameras are for tuya, but I don’t think it matters as long as they have rtps that works on applications like VLAN.
Thank you for your suggestion. I will record this issue, and we will find a corresponding device to test and reproduce the problem. I will get back to you shortly. Thank you for your patience!
Could you please provide some screenshots of your configuration on different platforms as well as on iHost? Thank you!
a screenshot doesn’t help, because each camera has its own settings, its own data stream. Install ODM (ONVIF DEVICE MANAGER), make sure to set the same access password for all cameras, in ODM put the user admin and the password set on the cameras. ODM will scan the cameras in the LAN and will provide you the url for the video stream of each camera.
Thanks, I’ve tried several times but I always get the error “failed to respond, try again or later”.
In VLC the stream works without any problem, and it also works with ONVIF Device Manager
After the search and entering credentials, ONVIF Device Manager provides these stream URLs:
rtsp://192.168.1.92:554/tcp/av0_0
or
rtsp://192.168.1.92:554/udp/av0_0
I also tried the following (which works in VLC):
rtsp://user:password@192.168.1.92:10554/udp/av0_0
rtsp://user:password@192.168.1.92:10554/tcp/av0_0
I have the same problem, In this case it seens that the problem is le logic of validation, that only takes the IP address to validate duplicated items, this logic works with IPs camera but not with DVR/NVR, please change validation logic so we can add multiple cameras from our DVR/NVR
I’m adding an RTSP camera to eWeLink CUBE on iHost. The camera is added successfully, but when I try to play the video, I only get a gray screen. At the same time, I check the RTSP stream and it plays successfully in various applications. What the problem could be is unclear.
Are you using an h.265 stream?
I tried my cameras with h.265 but the ihost hardware seems to weak to handle it (no picture or just stuttering)
on h.264 its working fine
try stream with lower resolution
