I have to report another problem. I had few zbminiL2 working with no problems in few no neutral positions. Recently I purchased another 4 together with the e1gsl switch. All of them are going reversed back right after clicking them, on or off no difference. 1 of 10 times will stay without being reversed immediately. Clicking from the app there is absolutely no problem, turning on or off with no problems, so I suppose is not something with load! Any ideas? I will send feedback in a minute.
You don’t specify what you mean by writing “clicking them.” I assume you’re referring to a switch connected to S1/S2. What kind of switch? The device supports a rocker switch by default. If you want to change the switch type, press the button 3 times and watch the green LED indicator flash 3 times quickly; then the type is switched successfully. No “going reversed” back right after pressing happens.
I am using them with the sonoff e1gsl Switch. Truth is that i didn’t know how to change from switch to pulse mode.
Thanks for the tip! I will try it in few hours.
It’s a momentary switch, so obviously you need to change the mode.
that fixed it for me. thanks!
How do make a request with sonoff to have this as a setting on ewelink?
