Dual-R3 meter based scenes
Can you build a scene based on Dual-R3 instant energy readings?
For example: “switch this Basic-R2 ON when Dual-R3 Power value is greater than 1kW”, or “switch this Basic-R2 OFF when Dual-R3 Current value is lower than 1A”
I will appreciate if you share any experience with this matter, thanks!
In case you have devices in Home assistant (i.e. via iHost and HACS installed) you can do that.
Thanks a lot for your answer! I haven’t quite jumped into those platforms yet (just eWeLink for now) but I’m taking good notice of your hint just in case.
