Hey,
Product name: EWelink Smart IOT Camera Wireless WiFi Intelligent Indoor Two Way Audio Mini Night Vision LAN Network Home Monitor
FW Name: GK-100XF11B
I was wondering what was the PSK / SSID password for this? which is being spawned when booting
dhcpname=IPC-EWLK-035516-LEHDF
OK
OK
killall: udhcpc: no process killed
Configuration file: /mnt/mtd/ipc/cfg/ap.cfg
drv->ifindex=3
l2_sock_recv==l2_sock_xmit=0x0x3305d8
+rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
Using interface ra0 with hwaddr 30:4a:26:ea:14:27 and ssid 'HAP-EWLK-035516-LEHDF'
rtl871x_set_wps_assoc_resp_ie
rtl871x_set_wps_beacon_ie
rtl871x_set_wps_probe_resp_ie
rtl871x_set_beacon_ops
rtl871x_set_hidden_ssid ignore_broadcast_ssid:0, HAP-EWLK-035516-LEHDF,21
Additionally is there any way to obtain a web management interface for this device locally that isnt https://web.ewelink.cc/? because my video doesnt even load on that webapp. loads on the mobile fine.
If it can be disclosed whats the telnet password on the device i genuinly need it for recovery.
Lastly, the UBOOT doesnt allow us to interrupt the boot sequence with ENTER
U-Boot 2012.10 (May 29 2019 - 11:20:26) for GK7102S dyzl-gk7102s-gc1034-v1.0 (GOKE)
HAL: 20160804
DRAM: 64 MiB
Flash: [W25Q64FV] USE 4X mode read and 4X mode write
8 MiB
NAND: [No SPI nand]
SF: 8 MiB [page:256 Bytes] [sector:64 KiB] [count:128] (W25Q64FV)
In: serial
Out: serial
Err: serial
Net: Int PHY
Hit Enter key to stop autoboot: 0 <====== HERE NO MATTER WHAT YOU PRESS IS IGNORED
[PROCESS_SEPARATORS] sf probe 0; sf read 0xc1000000 0x50000 0x160000; bootm 0xc1000000
put param to memory
mem size (47)
total mem size (64)
bsb size (1)
usr size (0)
the kernel image is zImage or Image```
