Compatible Flood sensor
Hi all,
could you please recommend a flood sensor which can be monitored with eWeLink app?
Which has the best support for eWeLink app, to actually work without issues?
Thank you in advance.
Hi there, this water leak sensor is compatible with our eWeLink App. Check out the product details at https://s.click.aliexpress.com/e/_DBeGY6x.
Thank you Peter.
As i can see, this sensor can’t work without gateway.
Is it possible to pair this sensor with Sonoff bridge, or it has to be Zigbee gateway from the link above?
Sensor is using Zigbee 802.15.4 protocol so it could be possible.
Hi there, to be honest, I’m not sure whether this sensor works with Sonoff gateway or not. For the sake of compatibility, we suggest you get a corresponding gateway. Maybe you can confirm by starting a live chat with the store staff at aliexpress.com. Hope it helps:)
Thank you Peter.
I’ll try to find something that works without a gateway.
I have this sensor and it works with Sonoff Zigbee bridge.
Thank you for the info.
I just want to use Sonoff bridge, don’t want any other gateway except Sonoff.
Do you have any other third-party devices paired with Sonoff bridge?
It would be helpful if you could share that info.
Yes I have, I have Zigbee switches from Eachen, more specific I paired duble switches with and without neutral wire. They are very close to Sonoff mini but can controll two circuits.
