Compatible devices works with home assistant
Compatible Devices
The following list presents what eWeLink Support devices you can configure and control on Home Assistant.
DIY Smart Switches
|236x236|236x236|236x236|236x236|
|Wi-Fi Smart Switch|Wi-Fi Smart Switch with DIY Mode|ZigBee DIY Smart Switch|Wi-Fi Smart Switch with RF Control|
|SONOFF BASICR2|SONOFF BASICR3|SONOFF BASICZBR3|SONOFF RFR2|
|Wi-Fi Smart Switch with DIY Mode & RF Control|Wi-Fi Smart Switch with DIY Mode|ZigBee Smart Switch|Wi-Fi Smart Switch|
|SONOFF RFR3|SONOFF MINIR2|SONOFF ZBMINI|SONOFF DUALR2|
|2-Gang Wi-Fi Smart Switch|Wi-Fi Smart Switch with Energy Monitoring|Wi-Fi Smart Switch with Temp. & Hum. Monitoring|4-gang Wi-Fi Smart Switch with RF Control|
|SONOFF DUALR3|SONOFF POWR2|SONOFF TH10/16|SONOFF 4CHR3/4CHPROR3|
|Zigbee USB Dongle|Wi-Fi Smart Lamp Holder with RF Control|USB Smart Adapter|
|SONOFF ZigBee CC2531 USB dongle|SONOFF SlampherR2|SONOFF Micro|
Smart Plugs
|Wi-Fi Smart Plug|Wi-Fi Waterproof Smart Socket|Wi-Fi Smart Plug with Power Monitoring US Type|ZigBee Smart Plug US Type|
|SONOFF S26|SONOFF S55|SONOFF S31|SONOFF S31 Lite zb|
Smart Wall Switches
|236x236|236x236|
|Wi-Fi Smart Wall Switch|Wi-Fi Smart Wall Socket US Type|
|SONOFF TX Series|SONOFF IW100/IW101|
Smart Lighting
|236x236|
|236x236|
|Wi-Fi Smart LED RGB Light Strip|Wi-Fi Smart LED RGB Light Strip|Wi-Fi Smart RGB LED Bulb|
|SONOFF L1|SONOFF L1 Lite|SONOFF B02/05-B|
Smart Home Security
|433MHz RF Bridge|Wi-Fi Wireless Door/Window Sensor|ZigBee Bridge|
|SONOFF RF Bridge|SONOFF DW2-Wi-Fi|SONOFF ZB Bridge|
|Wireless Switch|Temperature and Humidity Sensor|Motion Sensor|Wireless Door/Window Sensor|
|SONOFF SNZB-01|SONOFF SNZB-02|SONOFF SNZB-03|SONOFF SNZB-04|
There are much more device support, but those are not Sonoff.
And when you use AlexxIT SonoffLAN even more devices are supported.
Are all Zigbee devices compatible, Im using the new EACHEN eWeLink Zigbee Bridge Pro and have found Zigbee devices which work on Tuya and would like to buy and add them to eWelink
https://www.amazon.com/zigbee-sensor/s?k=zigbee+sensor
will they work? what info will we get?
Hi there,
We haven’t tested it ourselves. Basically, the workflow of the eWeLink Smart Home add-on is to sync the entities of Home Assitant to the eWeLink system. At present, the eWeLink Smart Home add-on supports syncing some lights and switches.
so if i understand correctly the future road map, eWelink will sync eventually to HA without the add-on? I need some specific sensors for my industry and believe the Zigbee eWelink devices are great. Could I have sensors made to integrate directly to eWelink via Zigbee?
eWeLink Smart Home add-on is required.
